Root "Working" Beats Audio Installer!
Well i found this in the "Rise All Thing Root" forum,
This is the original Beats installer from play store ---> https://www.dropbox.com/s/zvffj01zrkm088c/com.motioncoding.beats.pro.5.apk
The difference is that it was edited to not brick your phone! Thanks to "MyFormIsCrack" over on the Rise community for editing the apk file.
Just install the apk and run.
Makes our phone sound amazing!!
And all credit goes to MyFormIsCrack for this edited apk.
Be sure to make a nandroid before anything, better safe then sorry..
I would be careful with this stuff. Several people have posted on this forum that they brick their phones from installing Beats Audio.
Im not sure if this installed correctly on my phone, but this is what I end up with.
It looks like it installed fine but the squares should say
Install
Uninstall
Settings
Support
But they seem to be blank, what screenshot app are you using?
I am using the screenshot tool that is built into sleipnir. If I click on the blank boxes I still get the functions, just seemed a little odd that nothing was in them.
Well its not the screenshot then, hmm that is strange, try uninstalling and reinstalling
Here is a mirror, hosted on my own space at DevHost, for those having trouble with the download of the .apk. Nevermind :P
Also, Beats = Awesome?
Hi Artine . The beats you posted above crashed equalizer fx on Sleipnir 2.4.0.2 . I did try the one posted by BOINICLE38 here http://androidforums.com/elite-all-things-root/715753-new-beats-installer.html . It works fine for me . Works with equalizer fx . This is the best combo I've found . Equalizer FX is here https://play.google.com/store/apps/details?id=com.devdnua.equalizer.free&hl=en and the Beats audio is here https://play.google.com/store/apps/details?id=com.RockoDevAudio Try it out and see how it works on you phone people . Remember only on Rooted roms folks . I have been an Audiophile for over 35 years and I have to say this phone sounds terrible . These two apps have made this phone sound somewhat decent for me . Have fun people and peace .
Weird; I mirrored the .apk from the DropBox link in the OP, lol.
In any case, I'm an audiophile too :p I'm intrigued to check that combo out!
I got it working with Ecksperia, although I had to remove the DSPManager (using Titanium) and the Walkman app now crashes. Google Play however works. Not sure I can tell much difference. I have a good pair of Sony Headphones. Not sure yet if its worth keeping, if I could get the Walkman app working again with it I may do so.
The thing about beats though afaik is that without beats headphones it's pretty much useless, at least that's what I was told by my friend's bands sound guy
Plus all it does is enhance the bass, that's why I like things like dsp, it's an all around audio enhancer
ICS is what I use it on. But I have a different phone now and it came preinstalled on my custom ROM. :] Trust me you will like it more then DSP Ken.
