working CRTanimation for a70=beta
samrox144
Android Expert
this is a beta version......
how to install
STEP 1
1=download and copy to sd card
2=reboot recovery
3=take back up
4=flash file and reboot
IF WORKS PLEASE HIT THANKS
LINK=Multiupload.com - upload your files to multiple file hosting sites!
i this doesn't work flash this
link= Multiupload.com - upload your files to multiple file hosting sites!
STEP 2
1-download build.prop
2-copy to sd card
3-using root explorer copy it to system
4-set permission
read write
read
read
link=http://www.multiupload.com/X75S6H0CLO
try this in droidmaxxv2 or v3
ok try it with my rom benchmark 890
sorry it sounds stupid but i want to know that should I partition my card for that ie for ROM nd if yes how will I bcoz recovery is in sd card then.post tell me the procedure in simple steps I m very confused for installing ROM and partitioning nd wat any abt apps in sd card.though I hv took backup of those will it b safe to partition the card directly.rply please. want to try ur ROM .have downloaded it.
Take backup through pc and apps by titaninum. recovery will be phone memory.....partition it to swap 32
Ext-512
After that copy everything back
how to install
STEP 1
2=reboot recovery
3=take back up
STEP 2
2-copy to sd card
4-set permission
read write
read
read
rom will be updated tommrow or mid night
This wont work as well!! If you want it just head over to market https://market.android.com/details?id=com.katecca.screenofflock&feature=search_result
@Subro
Ive tried Screen of and lock.. its a widget that u must press to lock ur screen.. the power button wont work and the animation is UGLY :/ .. original GB animation looks awesome
hey try this and see if it works
1. Copy the files from that folder onto your sd card
2. In Root Explorer, move those files into system/media/video/shutdown on your phone (if you don't have a /video/shutdown folder set up, you can just create them.
5. This will give you the TV off effect on shutdown!
As said above, I don't think we can make it work (yet!) for just turning the screen off, but it does create a cool effect for a shutdown animation.
link=MEGAUPLOAD - The leading online storage and file delivery service
Any news on this?
Well that guy has released the source now.
Gonna have a try on my natty ;)
See my previous comments.
Lol....what a noob I was that time, even worst in English (no punctuation marks :p
@sam- Are you working in building with his sources here--
https://github.com/doixanh/X8Features/tree/master/FroyoBeam ??
Do hv a look on it!! His progress on it says--
- Screen on : Good.
- Screen off : Good.
- Animation when screen time out: Good
That means all is set and working perfectly! We can try building after replacing those files!! (Hope you already hv those mega-sources !!:D)
Do something to make this work bro.. Atleast crt animations if we did not ever get source code..
I would have done that, but I don't have froyo sources synched! Nor I have my PC with me, its f**ked!!:( I can't build anything without sources!:(
I believe Sam already have sources downloaded and can build with those files by doixanh for CRT, but where's he gone?? Its been a long time I saw him here.........:confused:
Also, sadly, its very difficult to port related code from some already build Rom's framework! I tried once but no luck! May be I'll give it one more try when I hv my PC back............
