Im looking for a stable, custom, senseless ROM for my VM Wildfire S (a510c). Getting tired of running out or memory after doing the simplest things....
The only way to increase the internal memory is ROOT your device and have installed all the apps on SD Card by using Link2sd (or Apps2sd). Also you can remove the blotwares if you don't want.
___________________________________________
Hope this may be useful. (If really press 'Thanks')
My work is based on JMZ's excellent work, but his stuff was hosted on Goo. They had an incident in February and lost everything. I spent many hours of Googling trying to find another download source for his work, but I believe it has been lost.
