zombu2
Here a quick guide on how to get Wireless tether for root to work on the boost Evo Design 4g
1: you have to be rooted
2: download the apk from HERE
3: install apk
4: open prog go to settings and set device profile to generic ICS , then check MSS clamping and routing fix
5: start tether and voila it is working
i tested speeds with speedtest.net and i get 1.5Mbit down and 0.5 Mbit up
sadly i have no 4g in my area so when i got time i will make a run to the airport and try it there
3: install apk
