Root Working Xposed Modules for Us
Just got me a stylo a couple days ago and running katana,
So far, as others said g4 tweaksbox works great and is well worth the money.
I too have gravity box, but like the other devices I've used it on its hit or miss what will work.
I also second YouTube background play.
Lolistat is a cool little module - it changes the status bar color based on the app.
NotifyClean is another great module - let's you customize what notifications are shown.
I've also got True Silent Mode, VolumeSteps+, and wifi filter modules activated but haven't really tried them out yet.
I've also got Holo Themer currently active, but along with a semi-disabled Secure Settings* module, I can't recommend as I'm getting some weird reboot freezes requiring battery pulls that I've gotten narrowed down to one or the other or a combo of the two.
*Secure Settings is needed to use some features of Keepass2Android, but it seems like once you activate the needed part of Secure Settings you can disable the module and the KeePass features still work.
XQS Background themes and works on the Quick Settings toggles, I did try XBackground in desperation of a system wide background (Phone, Settings, Installer) and it didn't work at all, thankfully it was easy enough to remove and no major hangups or bugs with it installed and activated.
