Would a Tab 2 case for the note 10.1?
Caloy
Android Expert
I accidentally bought a Tab 2 case for my n Note 10.1. It's like a silicon case. Do you guys think it would fit? I'll be really pissed off at myself for being so dumb if it doesn't. =/
Edit: Subject should be - "Would a Tab 2 case fit the Note 10.1?"
It may, but will probably not.
Just got the case, it either doesn't fit or I'm just scared to pulling it too hard. And no there's no opening fort the S pen. Bummer! Lesson learned, when buying anything, but read first, even if you did search for Samsung Galaxy 10.1 in eBay. This =/
I ordered a case for my Note 10.1 and the company sent a case out for the Tab 10.1. Nope doesn't fit. I was scared of pulling to hard but, I looked up the sizes of both devices and the Note 10.1 is slightly bigger.
I was comparing my Note 10.1 with my friend's Tab 2 and additional plastic piece that speakers are built in is a little bit wider and higher in Note. Whole device is also slimmer.
So Tab 2 hard case definitely will not work with Note 10.1.
Some that say they are for the 10.1 note don't even let you take the pen out without removing from the case. I bought one from bestbuy that was that way and returned it and had to order online. Couldn't find one locally.
i don't know but i do not like the leather ones. they look very heavy and the speakers are partially covered in most of them.
i ordered chip magnetic one very alike to genuine samsung from ebay. will see if it is worth the money (
it wont let you take out the s-pen if your going to use the case for tab 10.1. im using the original case for note 10.1 and its nice.
