I know you can change the sweep options to do the following:
Sweep gestures (sweep finger across the capacitive buttons on bottom of phone):
Sweep2sleep: with screen on, swipe right to left to turn screen off
Sweep2power: with screen on, swipe left to right for power menu (simulated 2.5 second power button hold)
Sweep2snap: with screen on: swipe left to right and press Home within 2 seconds for a screen snap
Sweep2wake: with screen off: swipe left to right to turn screen on (disabled by default for better battery life)
Phantom volume down: with screen on, touch between back and home for vol-down one notch
Phantom volume up: with screen on, touch between home and recent apps for vol-up one notch
Sweep2mute: with screen on, swipe from home to back for vol full down (vibrate)
Sweep2loud: with screen on, swipe from home to recent apps for max volume
Sweep2skipback: with screen off, swipe from home to back to skip back a track (when listening to music)
Sweep2skipforward: with screen off, swipe from home to recent apps to skip forward a track (when listening to music)
Sweep2deepsleep: with screen off, swipe from right to left to temporarily disable sweeps while screen is off (until screen is turned back on: prevents pocket sweeps)
But I wouldnt be suprised if you could change them to other things. I would PM the dev and ask about that, because its probably over my head
