Root Would like a VV5 firmware flash
Peiko
I kno I can use the. cab file and all the other steps, but I have no computer. Is there a way to do it over the phone only or maybe someone make a flash able file to use on recovery.miami guy did VV3 maybe something like that. I really would love to have VV5 now that it is rooted.
Someone get this guy a cwm back up of vv5 (clean back up of course)
Thanks jlede, but it doesn't look like its going to happen.lol
If I flash with miami guys VV3, do you think I can go to metro and get the update to VV5 with out a problem? I kno it has to be in stock rom and unrooted. Think that will be enough to fool them into doing it for me?
HERE YA GO! The very first thing you should do is make a backup before flashing this and please know that I AM NOT RESPONSIBLE if anything goes wrong or happens to your phone after you use this so please only use this knowing that you do so at your own risk... Ok now that thats out of the way :D download ---> (vv5 backup) once its downloaded extract the vv5 folder from the .zip and then place it on your SD card here --> clockworkmod/backup/ once you have done this then you will need to put your phone into Recovery Mode (CWM) once there go to -backup and restore- then -restore- then -vv5- let it run then reboot your phone, after the phone fully boots-up you should reboot/restart you phone one more time before using, I hope this works for you.
EDIT:
If this works good for you let me know and I will make a thread so others can have access to this as well
EDIT:
I tried the thanks button and it asked for my cc #!!!!!!!!!!!!!! :p
EDIT:
Downloading now and will make back up. Ill let you know how it goes in a bit.
Update: It worked fully and is rooted.xD Makes life so much better. Thank you guys.
Does this version not have quick memo?
Thts great, I will post it in its own thread later and yes vv5 has quick memo, you just have to press the volume up and down at the same time and it will pop up for you
It took a bit to get QM started but it finally worked after an hour or so. Will def donate for a monster or coffee.xD
I did the restore but its seems like the sw stayed at ms840zva
You may be interested in this
http://androidforums.com/connect-4g...ct-4g-flashable-vv5-firmware-basband-zip.html
