Accessories Would this fit over the Seido 3500mah battery?
I actually broke my seidio battery cover case and was looking to buy a new cover for my seidio 3500mah. Does anyone know if this battery cover would fit it? Or if the sprint cover for the 2600 mah battery would fit? Thanks for the help
HTC Evo White Extended OEM Battery Door Back Cover NEW - eBay (item 310275467040 end time Feb-27-11 12:49:36 PST)
That IS the Sprint cover for the 2600mAh battery as far as I can tell. Same exact cut and shape with High gloss white as the one they include extra in the Sprint kit. I verified by comparing it to mine.
I know that the Seidio 3500mAh battery is thicker than the Sprint 2600 mAh. While the Sprint 2600mAh battery door does have a little extra room, I'm not sure that it is enough to accommodate the 3500mAh battery.
My gut says no, but someone else with both styles might be able to give you a definitive answer.
