Cannot post to xda need help revolution stuck rebooting at LG screen CWM Installed can access but all installs abort can't find info on xda cannot post on xda please help!!!!
Just had this happen to me this am...do a hard reset(hold down power. +volume keys) then follow text to erase all data. My esteem rebooted right into recovery and I flashed a backup from two days ago.
If you did back up your previous rom, then you should go in *back up/restore* section in CWR and then select "restore". Look for your previous back up and flash it.
If you don't have a back up , then do a wipe data/factory reset in CWR.
