Root wrong forun i know but help needed
thequeenscheese
Android Expert
Hi only posting in here as there more peeps and better experience i think,
Need some help ive tried to put the cyanaogenmod on the tab 2 10.1 ive installed rom manager and got a clockwork recovery going on, i wiped the dalvik cache went to install from ext sd it didnt like the rom and failed, so i went into rom manager with in the tab but it did not find the ext sd, so i then put the rom on the internal sd and ran it from within android and the rom manager, now all i get is the tab boot pic then the cyanogenmod spinning boot logo?
odin does not recognise dev nor kies either for restore option..
Did you wipe data and cache as well? If not boot back into recovery and wipe them then reboot.
sussed it dunno what occured had to plug charger in to turn it of then managed to get to recovery select reboot and it booted to cyanogen rom have to say tho not sure if i prefer it or not..
gone back to stock didnt like the cynana after all that anyways.. even tho it was 4.2.1 not 4.1.2.. had some nice features but just too many down sides to the ups on the tablet, might give it a bash on the phone tho..
