Root WTF am I doing wrong????? ODIN issues
Dante04SRT
[copied from XDA; just wanted some add'l exposure]
I am trying to flash a ROM, but I simply can't get ODIN to work properly. I've used ODIN 1-click and the other ODIN and both get stuck - the 1-Click gets stuck on file analysis and in other ODIN version got stuck on Initialization (two steps AFTER file analysis). It freezes either way... and YES, I did get the Com port assignment; all USB drivers are loaded/installed.
Needless to say, my phone now reboots with the stupid Phone + Triangle + Computer thing...
I can still get to Download Mode but I'm a bit confused as to where to go from here. Should I use a different computer or try a different method or what? Based on the research I've done, this should have just taken off and worked, no issues....
The phone was a bone stock flash (although rooted) and I was following the steps outlined in Connexion's video.
HELP!
After switching over to my laptop and installing the drivers fresh, I got it back up and running.
I just flashed Andromeda 1.1 so I'll report back.
Thanks!!
One thing I found is that when you connect via USB, Odin doesn't work when you plug it into a USB hub and it may be you have to connect it to the rear USB in the case of a desktop. (even if you got the COM port to show up)
If the developer supplies an upgrade zip, then you don't have to.
Good to know! I'm planning to flash Serendipity from Cognition and have been putting it off to re-study the Odin process. But Serendipity provides a zip flash so I'll try it through CWM instead.
+1
Yeah, you never want to flash with the phone connected through a USB Hub or anything like that. Even the front panel USB ports on a desktop aren't really recommended.
If possible, you want to plug in straight to the computer's motherboard (rear USB ports).
Going from Cog to Serendipity, I would Odin back first...just me though...someone else with more experience may correct me.
Absolutely! As I said, from one developer to another, one ROM to another, Odin back, full master clear, etc. and then do a fresh install. Once you've settled on a ROM (as I have Serendipity) then you can do the flash upgrades without wiping. Mikey usually tells us if he feels we should do a full flash, that happens sometimes when you have major step versions.
yeah it's really hit or miss... i had to take out the plug, try a few slots on my pc, then that would stop, and I'd have to try another port. it's ridic.
am also planning to try our Serendipity from Cognition 4.2.1
so I should ODIN to Eclair 1st then flash Serendipity, correct? do I need to disable voodoo via CWM first or just ODIN to stock? sorry am novice on this.
btw which ROM would you recommend for a newbie? I find Darky's & Cyan too complicated & too technical for newbie.
many thanks in advance to help from gurus
YOu don't have to disable lag fix, just use Odin, flash back to stock, and then flash Serendipity.
