This problem happened yesterday my phone got extremely hot. I went to the battery stats and found that Package Access Helper was using 29% - 35% of my battery.
I got alot of alerts from watchdog about the package access helper using up my CPU
I searched around and there are people who had similar problems that i have . I found out it was a Service app that had something to do with installing and uninstalling apps. So i killed the app and tried installing something from the Google App store and the app i downloaded was stuck at the "Downloading..." stage
I turned my cell off and on multiple times but it didnt fix the problem. Can anyone help me ? This problem appeared randomly ?_? i dont even mess around with my phones settings. :/
EDIT:
I did what Frisco told. But after waiting for it to calculate 10-15 min i finally pressed the Clear cache button and nothing happened.
Something mysterious happened there is something called com.rootuninstaller.bat.. using 9% of my battery dafuq !?
EDIT:
