ok....how ?You need to set the APN to your carrier's requirements.
There aren't any ROMs that you flash with the flash tool. The only thing you use the flash tool for is to downgrade to zv3 using the tot file, which isn't a ROM. What exactly were you flashing?I used LG flash tool and flashed a Rom for the volt used everything like before. Can't recall exaltoy if it was for boost it virgin if that matters. If I can't restore for boost
can it be used by another carrier?
Would flashing the zv3 tot restore it? I mean, it would wipe everything, but it would fix it, right?Sounds like your nvram got wiped. Were you trying to flash using the LG flash tool? A normal ROM flash shouldn't have been able to affect the NVRAM.
Unfortunately if your nvram did get wiped and you don't have a backup, there's pretty much nothing you can do to restore it.
What are you seeing on Settings > About Phone > Status?I used LG flash tool and flashed a Rom for the volt used everything like before. Can't recall exaltoy if it was for boost it virgin if that matters. If I can't restore for boost
If the NVRAM has been lost then no flashing the tot wouldn't restore that. NVRAM is phone specific as it contains your serial number, aa key and other important stuff like that for connecting to the network.Would flashing the zv3 tot restore it? I mean, it would wipe everything, but it would fix it, right?
I've gotten that when flashing with cwm. Try flashing the zv4 ROM and radio from donjuro.This is what I see
That is a problem with the backup itself. It means that the data is somehow changed from how it was when it was created. Have you messed with the backup files? Are you restoring with the recovery that made them?Thanks for for the responses. I do have backups. When trying to restore them I get error md5 mismatch.
