I noticed the keyboard on the X doesnt have the little icon on the bottom so that you can make the keyboard disappear if you want to look at something then come back to typing. Does anyone know if there is a way to do this or not?
Idk. Would pressing the back button make it go away?
press and hold the menu button to toggle any keyboard.
That's how it works on both my Droid and my Wife's Eris. I'm guessing it is probably how it works for Android devices in general.
Actually I have the Eris, it has a little drop keyboard button in the bottom left corner as well. Not sure how that's gonna work on the X.
Yeah i had the eris to at first and went to an incredible and both had the little drop keyboard button in the corner. Then i installed the X keyboard on my incredible and it didnt have the little button anymore
you can also swipe your finger down the keyboard to make it go away
