X10 Car Dash-Mount?
TheDriver
Anyone who've got their X10 mounted on the dash of the car and can recommend a good brand or got any ideas?
It already works amazing with the Google Navigation, but I'm also thinking of the same idea, the Motorola X Droid guys have, either with having the place, where the camera lens is visible or breaking the part of the mount plastic, so it works like a dash cam too.
i have had various mounts in the car and the brodit is the best by far, fits perfect and you are able to change from protrait to landscape easily.
you pay for it though as there not cheap, but if you have any sort of case on it then you will have to remove that before placing it in the brodit.
anothinger bonus...you dont have to put holes in your dash to fit them either!!
thats the last one i had...except on the air vents as hate stuff stuck to the window
tried to turn it to landscape without unscrewing the nut to loosen it and broke
hence the brodit
The Brodit seems to be pretty popular.. and expensive.
The Windscreen Car Mount on ebay - That one looks good, but I guess in my case, I would need to cut the part, where the X10's Cam lens is. If that's possible, it's great!
