Help X10 mini Pro need help!!
Asim2011
Hey guys I purchased a Mini Pro in February on Vodafone since yesterday it has all started to act strange, by Restarting it self again and again I did a repair via update-service still same problem! No wireless or anything is on, I get to the home screen and 2 seconds later it will restart..I am on 2.1 Android.
Any one know a solution?
I'm sorry to hear. If you have updated and also tried to reinstall the phone software I think this problem must be caused by something else. Maybe you could try using the phone for a while without the SD card inserted? See if the problem might be caused by the SD card. You could also try with another SIM card to see if that might make any difference.
BR
Johan
SEAnswers
BR
Johan
SEAnswers
I already done that, but in does not matter since I have gave it to my retailer to repair now, so Thanks anyway.
Market is not found in my Xperia x10 mini pro pannel. Please suggest as what to do to get this application available on the pannel.
thanks
Unfortunately if you do not have Market listed in the menu of your handset that means it comes from a region that does not support this service. At this stage I am unaware of a way to install this application separately.
