Root X8 R00ted.Problems/Bugs/Tips/Info.
Blitzkri3g
Just thought it d be a good idea to talk about all these in a new thread! :)
I m starting with a weird one.
Since I rooted my phone,I cannot change individual ringtones/notifications.
I mean that whenever I try to edit a contact,it only lists the internal preinstalled ringtones/sounds and I have no option to use my music or mp3s.
Any suggestions?!? :confused:
N.
N.
If you scroll way down it'll give you option of music library
Hey! Come on now! :-P
The thing is it doesnt give me the normal option you re talking about at all. :-(
Maybe something to do with file permissions?!
The foldet "music" has files that are visible and playable by the stock player though.
N.
Are your market and applanet unstable after root/jit/app2sd? For market i just uninstalled update and now it's ok. But what about applanet? Does anyone use it?
working of Applanet depends upon Applanet server
if it doesnt work than probably the server is down, sometimes it takes days to get it back working :)
I know that. It's not that it's not working, it's unsable. As in I download, and half-way it force-closes the applanet app (android "cloase app" error message).
Applanet is buggy as hell at the moment.
Their server checker reposrts the servers online but still no apps.
Anyway,another solution that works for some people is deleting applanet s folder/temp files,uninstalling and installing it again.For me it still didnt do the trick!
N.
The damn phone started rebooting by itself after a manual reboot. :mad::(:mad:
The only way to prevent this is keeping the screen on.
I guess it has to do with ATK killing autostart processes...
N.
N.
you must have selected autokill frequency as "crazy" check out that
It is quite dumb to ask u Suhel.
I rooted my x8 using SuperOneClick. I partioned my 8GB. Now in DOS prompt when I enter command ADB SHELL it says ADB command not recognised similar error for su...i have made all settings correctly. I want to install App2Sd.
hmmm... there are three files in the superoneclick folder with their name starting with adb... copy those files in a new folder (make sure the folder name doesnt have space) now in cmd cd the path of this folder and try again
Is anyone having restart problem after rooting???
Phone doesn't restart during normal use but when u switch off and switch on, the phone keeps restarting for 1 or 2 times and sometimes even 4-5 times.
after applying JIT, the phone restarts everytime i plug in to a PC usb port and choose connect your phone.
When you connect your phone to PC normally you will get few options like connect pc, install pc companion and charge phone. if u click any of those options the phone will restart. instead click back and mount your sdcard from the notification bar. It worked for me before i rooted my phone. now after rooting im not having this problem.
i have experiencing this problem too, and after self restarting it randomly delete some files after several restarts.
deletes movies/pictures :(
but this trick works :D
Got prob whn applied app2sd for me.. Whn restart,, got several apps gone.. But whn restart again, some apps came back n some missing again.. Its like the card not load all the apps in thr..
