D Deleted User Guest Dec 13, 2010 #1 Does anyone know whether or not I will be able to stream media from the Desire HD to a XBOX 360?
Harry2 Extreme Android User Dec 13, 2010 #2 DHD manual says you are able to stream media from Desire HD to media players with DLNA ability Harry
E elisponge Lurker Dec 15, 2010 #3 Yes you can, I find using twonky is easier but if you want to stream movies the format has to be supported by the xbox but that's obvious really
