Help Xoom screen shaded on one side
Tsarmina
Hello fellow Xoomers :cool:
Here's my question:
I tap the bottom right icons which show time/signal strength/battery which brings up a slightly bigger field with this info (tap again for bigger menu starting with airplane mode). When I do this a shadow covers the right hand side of the screen- completely obscuring the apps icon and the + in top right corner. Shading is not evident at any other time.
Is this normal? :confused: Should I be concerned? I've had my xoom for almost 3 weeks. Bought at New Egg.
