Help Xoom wallpaper
kool kat2
Android Expert
why is setting wallpapers so screwy? how do i make wallpapers fit in right? i try so much resizing but i never get it right.
download Multipicture Live Wallpaper from the market, tons of ppl use this to fix that problem. Resizes the images perfect everytime.
Just add it from the live wallpaper list and set it to a single image source. Good to go.
that is awesome! haha,hy is it so complicated to begin with? thanks
I have noticed that when you select a wallpaper from the gallery it does not give you that option to crop the image because it simply loads one of those preloaded images. I was thinking if I load the files I want as my wallpapers into that directory would it do the same and not even ask you to crop the image. The only thing is I've been using astro to find the file but haven't been able to so far. Would someone here know where the file is located?
