Help Xperia Arc Wifi limited connection
steryman
Hi guys I'm trying to connect to a wifi router, it gets the IP but after that it says "Limited connectivity" and I can't access anything(Market, email, etc.).... so please help me to solve this problem!
I had the same problem. Guys try installing 'Blade Wifi Fix', 'REGPON wifi KeepAlive' and 'Wi-Fi Keep Alive' from Android Market and then see the performance. Try out also Wefi Connect.
if above apps not working..
are u sure router is connected with internet? if yes, maybe mac of your phone is not allowed on wlan?
i got same situation in school nowadays, so waiting someone to fix it so i can use it :D
Hi,
If your router using channels 11-13 or set on automatic scanning you will not be connect to wifi.
cheers :)
p/s you should check out XDA-Developers website regarding this matter.
I get this problem 2 weeks ago, the problem was resolved by re-install the firmware from SE website.
Don't forget to backup your data before you start!!!
