Xperia Ray battery issue!
Hi I am using Xperia Ray and forgot to charge it. I noticed the battery almost ran out so I shut it down and later plug it into the usb charge (both PC and wall) but nothing happen, it won't boot....even the charging icon not showing on the screen. Please tell me what I should do!!!
see
when the battery runs down and fone gets switched off, after that if u insert it to charger. it gives response after some time. like 5-10-15 sec
hence
put the charger
and push the start button, u will get a little vibration and then ur screen will come, showing soy ericsson. don't do it many times. just do it once. since it gets a little time to start up.
try if this helps
When the phone runs out of charge completely even when connected to the charger it might take a while to turn on or to even show any sign that is charging. So if possible just connect the phone to the charger and leave it charging for 10 to 20 minutes and it should be working just fine.
