The only thing you can try is to run a software repair using Sony Ericsson Update Servicehttp://www.sonyericsson.com/cws/sup...nloads/subject/updateservice/aino?cc=gb&lc=en ignore the fact that it say Aino, you select your phone when you run the program. It will wipe your phone back to factory settings so I hope you have your contacts saved or synced. Apps will have to be reinstalled.
Make sure your battery has plenty of charge before you start.
