parkerskouson
Hey. I'm running xplode Tom. I love it but every time I try to install a app it freezes an does a hot boot thing... how do I fix it?
parker
parker
parker
parker
Terminal Emulater should be baked into the Rom.
Open it up,
Type, "su" then press enter. After doing that it will request superuser permission. Hit yes. Then your keyboard will go away. I didn't know how to get it back so I press the back button and then reopen Terminal. Then you will type "su" again, hit enter,
then type, "a2sd remove" and enter again. It will reboot and should be fine after that.
Do not put the " quotes in with su or a2sd remove.
Naters
ok cool. and one more thing. every time i try to install a app it says could not be installed because of a error.. whats that?
hmmmm, i never had that problem 0.0, sorry =/
