Root Xposed module
Amen to that, brother! Plus, I think GB requires a vanilla ROM (no Sense, nor TouchWiz, et al), whereas XBlast doesn't care about that. :-)
I use Gravity Box. It works fine, better than XBlast for me. I don't think this has any Sense or TouchWiz. A couple things don't work, like hiding the clock on the lockscreen, but it doesn't break anything.
For the record, I'm also using Download2SD with no problems.
Here's what modules I have, had no problems with any of them
WARNING: XBLAST TOOLS JUST REKT MY PHONE
Causes android.systemui to crash. Can't access the menu to disable it, or access any part of my phone. Will need to find a way to get rid of it.
Boot into safe mode. That will prevent Xposed from running. Then uninstall XBlast and reboot.
For everyone's reference, could you post what settings your were using in XBlast so we can isolate the issue and avoid it?
Doesn't that use up resources though? I try to keep things as low emissions as possible. I've never seen a toast for blocked numbers but maybe those blocked numbers haven't called me back again.
Didn't know there was a safe mode. I restarted my phone by mashing the power button during start up which disables xposed.
My modules:
BootManager
HandleExternalStraoge
Intelli3g
XInternalSD
On the surface, it does not seem like any of those should share resources with XBlast.
You get to safe mode from your power menu. Press and hold power button, then tap and hold "Power Off" then tap "OK" to reboot in safe mode
My modules:
BootManager
Intelli3g
XInternalSD
I honestly don't know what interaction there is between modules. My instinctive guess is that it was something within XBlast that was causing the issue. How did you have it configured?
Took xblast off my Volt, still use gravity box but now also use G2 Tweakbox. MUCH better it seems, I'm assuming because the "G2" is of LG origin. Anyway, works awesomely.
All you have to do to hide theclock on the lockscreen is swipe from the edge of the loskscreen and that opens add or remove widget mode and you can delete the clock widget and add another widget if you want.
I'm not talking about the widget. I meant the status bar clock.
