Root Xposed Theming
anyone having issues with fore closing after updating to Zv5?
  • yes
    Votes: 0 0.0%
  • no
    Votes: 5 100.0%
  • Total voters
    5
Theming stock Zv5.
What Launchers are you using and how smooth is it?
What xposed Modules are compatible for the Volt?
What other 3rd party apps are yous using?
I know we don't have a functional Rom working at the moment but I'm trying to Change everything on my girlfriends phone. I want to show her that the rooting process was worth it. She keeps having apps foreclose on her like FB and stuff. I'm guessing it's because I didn't wipe after I updated(through recovery) to Zv5.
If u guys can give me some pictures and ideas that would be awesome I know it would help a lot of people who just got this phone.
Debloating is your friend as far as force close issues goes. I use gravity box kk, android theming engine, g3 tweaks box and xblast tools to mod my volt, and between those, i get pretty much all the ui mods i want
What version of Gravity Box are you using?
Gravity box ver. 3.5.3.rl
Yep! Turns out, anything that works on g3 works on the volt
That's fraken Awesome, well than that means more moding for me ^_^, hey think you could help me with something- relating to lg Font changer, iknow this the place but can't find any help anywhere, been messing around with the system file but nothing seems to work.
I haven't been able to change fonts for individual apps, so if that's what you need help with, no luck. But i have used rom toolbox to change system wide font (it just doesn't change game fonts, which is what i was originally going for)
No no really for individual app, but like rather the entire system, won't change font, stay sticked to smartgothic font and no way to change it.
Yeah I did debloat it when I updated it. Maybe I didn't debloat enough lol
Thanks guys! G3 Tweakbox looks like it has most of the things I need !
As far as launchers go can I delete stock if I push a 3rd party launcher as system ? If so which one do u recommend Nova has always been good on my Note 3 but idk about the volt.
Question about APM, if someone can help. The REBOOT menu will not show for me at all, and I can't figure it out. Any ideas?
I haven't been able to use apm for months. I try to remove airplane mode or anything else and it crashes. I just use g3 tweaks box to get better power menu options
GravityBox also has advanced power menu options, I prefer them over G3 Tweaks.
Launcher:
Nova launcher pro
My thoughts:
It runs pretty smooth for me, and it's the only third party launcher I have ever used. I've tested others, but Nova takes the cake for me.
Xposed modules:
G3 tweakbox
My thoughts:
It is decent, but there are a few things that confuse me. Maybe it's just me, but I use different terminology for some of the panels. The settings are decent enough for most people.
Questions:
1. Anyone know how to change the theme of the contacts, dialer?
2. Anyone tested any downloadable themes for g3 tweakbox?
I'll add more when I'm on the computer, lol. I hate typing on my phone.
Quick tip...G3 Tweaksbox has an extended kernel info option so it does the date of the kernel in the phone info so you don't have to go in terminal to check.
