Root Xtheme theme engine stuffs
CYCONUMNUM
I use xthemes...right now I'm rocking one called Aventador...
xthemes can never get as extensive as original cyanogen mod themes...
but, the same as CM themes...they can be hit and miss....
here's a couple of collections...you can get a few on play store...but, if you look enough....but, also, allot if collections are fools just reposting other people's work...
http://rootzwiki.com/topic/113465-xtheme-enginexthemesnew-xthemes-collection-xposed-framework/
http://forum.xda-developers.com/showthread.php?t=2516001
open the module...let it tell you about that having to set it up stuff stuff...
ignore it....
click "back" on your phone once...
choose your theme you've installed...
reboot...
it always tells you to set it up....it's one of the hick ups of the last xtheme theme engine build....
been like that for......years I think ..lol 1 or 2...
I'm sure someone will correct that statement...
make sure your backed up...
the infinite themes are cool with their cryptic diamond battery icons....
the cobalt's are cool..
