SpaceFrank
Hello, all. I've had my Commando for most of a year now and have been pretty happy with it. Just as waterproof and shock resistant as my Rock was (aside from turning off sometimes when dropped, I guess the battery mounting isn't stellar... but that's an issue for another time).
I recently did a factory reset, as I had frivolously downloaded quite a few apps I didn't need and the phone was running slow as hell. Got everything set back up the way I wanted, and have encountered no hangups or frozen home screens since.
Now, for some reason, when the screen is turned off, the LED blinks yellow even when I have no notifications. I think the notification alert is green, anyway. When I press a button to turn the screen back on (showing the slide lock), the LED turns off.
The battery level is fine, and it does this whether the phone is charging or not. If the screen is on but locked while the phone is plugged in, the LED is solid red like it should be, but when I tap the power button to turn off the screen, it starts blinking yellow again.
I'm hoping this is something easy that I just can't think of. I have no idea what the yellow light is supposed to indicate, and I don't recall this happening when I first bought the phone. It's irritating because I usually leave the phone on my desk with the screen turned off, and just glancing at the light can tell me if I have a notification or not. Now the thing blinks all the time.
