Help Yellow LED notification won't go away
alamoe
Has anyone else had a problem with the LED lighting up whenever the screen is off. When I turn my screen off the LED lights up yellow and I don't know what it could be. I'm not using Light Flow, just completely stock. I've checked texts and missed calls but that doesn't seem to clear it.
There's an app causing the LED to light up. Look at your running apps. This should help you narrow it down. If you can't figure it out, post a list of apps you see under Running apps, and we'll try to help.
Thanks for the responses. I don't know what it was but I rebooted and its all clear now. And no, I'm not using youmail.
