Root Yellow Triangle & Droid Symbol
Greetings!
I did perform searches before posting. I found one post that seemed to help...
I have the original droid, 2.2.1, frg83D.
Rooted with Soup or Root One Step.
Running set CPU.
Installed Rom Manager. Flashed Clockwork Mod Recovery. Performed Nandroid and MyBackUpPro.
Out of curiosity, tried to boot into recovery & got the Triangle & Droid Symbol. Had to pull battery.
Performed search, found a post that suggested flashing Sprecovery, and then again flash ClockworkMod Recovery and that should get CM to "stick".
It seemed to. Downloaded Chevy rom& Kernal Via Rom Manager. Booted into recovery and Yellow Triangle.
I must be doing something wrong. I've read hours of posts here. Could the One Step Root have screwed things up?
Any Suggestions?
Thanks!
Dave
Hey, this is the same thing thats happenign to me currently. I was using UD 2.5 for quite a while so i figured i'd try UD 3.0. When i tried to install from sd card, it gives me the triangle and shit. I've RSD Lite'd my phone, tried the whole setup again and still got it. I'm confused.
EDIT: i went bak into rom manager, flashed SPrecovery then reflashed clockwork and it seems to have fixed my problems.
Dave
no youre not doing anything wrong,and the super one click app is not to blame. you are still using your stock rom,correct?
the prollem is that the stock rom replaces clockwork with its stock recovery every time the phone is rebooted. hence,while you are using the stock rom,youll need to flash clockwork again before booting into recovery.
once you install a rom,this will stop happening. if you want to continue using a stock rom,there are a couple of files you can delete and/or rename using root explorer. this WILL make clockwork "stick" ;)
That makes complete sense! Thank you!
Will Clockwork still "stick" if the phone gets stuck in a bootloop while trying a new rom? I want to be able to boot into recovery to go back to the original rom if I need to.
Thanks again for your reply!
Dave
it should.
the new rom does not overwrite the recovery,it simply does not have the same files that put the stock recovery back,like the stock rom. if something happened,clockwork should still be there. :)
edit:
if youre interested,heres what i did to allow clockwork to stick to my stock rom:
http://androidforums.com/droid-all-...very-unless-i-flash-clockwork-sprecovery.html
