I bought my Asus TF about 6 months ago...it still charges, BUT mine has always seemed like it only does a trickle charge. If I have the TF plugged into the wall outlet the battery icon doesn't change and when I got into the battery options in the settings, it shows it's not charge. However, if I leave the TF alone for a while it will show that the battery has increased. I let it sit on the charge turned off for 24 hours and it only got to 45%.
I checked videos and other threads about taking off the plug adapter and adjusting the pins and then putting the adapter back on...didn't help. I also saw something about how the USB plug sometimes gets loose and you can bend down the prongs slightly to sit the connection better..did that too...still didn't help.
I noticed that if I have the TF is standby and then plug it in to the charger, the screen comes on like it's charging, but again it doesn't change the battery icon or show that it's charging in the settings > about > battery section.
Any more ideas what it might be?
