Kairosgrammy
Member
Okay, the first thing I want y'all to consider is I'm not a techno nerd. I have nerd in me but not enough tech knowledge to be nerdy in that area. I had a note 2 until about a month ago. I got impatient for the jelly bean update that gave multi window option and so I rooted my note 2, first and only phone I've ever rooted. Put clean rom 3.3 on it and had the multiwindow function. Loved it. I didn't realize that the update to multiwindow was not nearly as versatile as clean rom's multiwindow function. Never knew until I upgraded to the note 3. Wow, extremely limitited.
I'm with AT&T running kit kat 4.4.2. First if I root the phone and install a custom rom, will I get the same multiwindow control that I had with my note 2? If the answer to that is yes, does it depend on the custom rom I install and if so, which custom rom should I install? Also, I've seen where it says you can't root a phone with 4.4.2. Is this true because on you tube found an instructional video on rooting an att note 3 with 4.4.2.
