i found this rom, and look from from XDA ported for a60 by Banjo0917, major issues has been solved and now it is working great with not even with single FC. so guys pls have a try to this flawless rom
Yonip V5.2 ICS Themed [NEW] by Banjo0917
Changelog:
+Fix minor bugs of previous version V.5.1
+Fix lag issue of previous version V.5.1
+Some UI Changes
+Native Swap support
+ext2 support
+Fast, Smooth, & Stable
Download LINK
YONIP_V5.2_A75_CM.zip
Market Fix
YONIP_MARKET_download_FIX.zip
How to install:
1. Install ROM in recovery
2. Reboot to System
3. Reboot to recovery then apply Market Download Fix
4. Reboot to System
5. Enjoy
once booted open play store try to download something. it will close. again reboot in recovery and flash the play store fix.
Note apply play store fix only after opening play store once and accepting the terms.
I am using this rom for last 4 days not even a single issue found.
Note: i am not responsible for Bricking Your devices
Changelog:
+Some UI Changes
+ext2 support
Download LINK
Market Fix
How to install:
2. Reboot to System
4. Reboot to System
5. Enjoy
