Root You are not bricked
kagevazquez
The s-off process is not easy for everyone it takes a few tries (I got it on the third time) if you seen the screen with the bear DON'T FREAK OUT YOU'RE NOT BRICKED just exit the program and try again and if it didn't work TRY IT AGAIN AND AGAIN AND AGAIN!!! I see people say they are bricked every single day but YOU'RE NOT! Just keep trying .....and make sure your battery is full if you think it's going to take a lot of tries
I was able to do mine in the first try, but then I typed
Code:
fastboot oem writesecureflag 3
and I actually ended up bricking my phone lol.
Code:
You sure it's bricked?
You should only do that command with a complete stock phone. Always run the RUU before putting s-on.
