Root You can't fix stupid!
800487
I hate to make my first post to this website a request for help but i got myself into a pickle. During a moment of less then average intelligence i deleted the contents of the throttle folder in data/system/throttle. There were three files contained in that folder and after removing them my 4G and 3G speeds are running at the throttled speed of about .29 MBPs. If anyone has a copy of those three files from ICS 4.0.4 you would be my savior! Thank you in advance!
I make it a point of never try9ing to fix 2 things - stupidity and pig-headedness. This was neither, it was a mistake. (Like I've never made one - in the last 3 seconds, because I made a typo in this sentence.)
Forgive yourself.
Sorry, but I don't have ICS or an HTC, so I can't offer you more than sympathy.
I just checked my device and I only have two files in there and one of them is a temp.
Don't think that is what you are asking for lol.
Honestly at this point i will take those two files if you are okay with that. I believe one of them was a temp. I tried finding a nandroid backup to pull them from but didn't have any good luck with that! ):
I will upload them and give you the link. Check your Messages soon. Should only take me a few minutes.
Done. I'm with boost mobile if that is of any concern. Good luck.
