YouTube still wont work on 4g
My youtube use to work when I first got my Esteemon the 4g network.Now it only works with wifi.I know there has been other threads about this but I've tried going into the settings,manage app and delete the cache and data, but it still won't work.I've even deleted it and reinstalled, but to no success.Anyone have any suggestions?Thanks!
how much is your monthly plan/bill for metro? if it isn't 60$ I believe you have a limit of how much you can watch which seems ******ed to me, considering youtube is free
Are you rooted? Because the same problem happened to me, my youtube wouldn't work on 4G only on wifi, so I unrooted my lg esteem and youtube worked again =] hope this helped.
Im thinking I reached my limit..No, Im not rooted.Ill see how it goes my next billing cycle.Thanks everyone for the replies.
I'm on a $60 plan.. I rooted / unrooted/ cleared cache..browser cache./ factory reset CWM with gingeresteem rom. Stock/ no avail. works fine on WiFi on all the above scenarios except on 3g or 4g. I think its a metro network issue with my home area. It randomly worked when I was in fortaluderdale. My home area is Miami/Kendall if this helps any.
uhmmm. did you try using my method. go ahead;
http://androidforums.com/lg-esteem/...ithout-doing-factory-resets-phone-trades.html
I didn't know there was a limit o_O? Mine stopped working about 3wks ago. I'm rooted and on the $45/month plan.
Root was not the problem, you messed something up on the phone.
Unless you have the $60 4G plan (how do you have the $45 on 4G?) there is a 1GB/month limit for streaming media.
Finally Metro Agreed they will replace my phone. I have to wait a week. They ordred one from factory. Hopefully that will fix the youtube issues.
