Zenexp requires repartition of SD card?
Blitzpwnage
Alrighty so im very tempted to go to Zenexp and have my nandroid backups and everything, does the nandroid backup my apps too? I also have my ext. backed up can i wipe and do factory reset and still be able to go back to my old image? Also do I have to partition my SD card again?
i dont use partitions or anything but a nandroid b/u saves everything for me. just make restores of all the roms and you can change roms on the fly.
edit: i find zen to be more form than function.
Yea ive finally realized that lol well I dont have to format my SD card right just wipe the ext. and the dalvik and reset to factory correct? :D
I only have to wipe dalvik/factory because i dont use a2sd. I think that you would have wipe ext, check the faq.
Ive formatted my card once, the day i bought it.
That's the way I've always done it. I've never formatted my card except for when I first bought it.
