I've downloaded HTC Sync and installed, downloaded DooMLoRD_v4_ROOT-zergRush-busybox-su.zip from here
forum.xda-developers.com/showthread.php?t=1321582
When trying to run the runme.bat file it seems like it is working, reboots when the install is done, but when i run root check it says I do not have root access.
Is there anything I should look out for during installation?
Easy rooting toolkit (v4.0)
created by DooMLoRD
using exploit zergRush (Revolutionary Team)
Credits go to all those involved in making this possible!
[*] This script will:
(1) root ur device using latest zergRush exploit (21 Nov)
(2) install Busybox (1.18.4)
(3) install SU files (binary: 3.0.3 and apk: 3.0.6)
(4) some checks for free space, tmp directory
(will remove Google Maps if required)
[*] Before u begin:
(1) make sure u have installed adb drivers for ur device
(2) enable "USB DEBUGGING"
from (Menu\Settings\Applications\Development)
(3) enable "UNKNOWN SOURCES"
from (Menu\Settings\Applications)
(4) [OPTIONAL] increase screen timeout to 10 minutes
(5) connect USB cable to PHONE and then connect to PC
(6) skip "PC Companion Software" prompt on device
CONFIRM ALL THE ABOVE THEN
Press any key to continue . . .
--- STARTING ----
--- WAITING FOR DEVICE
--- creating temporary directory
mkdir failed for tmp, File exists
--- cleaning
--- pushing zergRush
1441 KB/s (23060 bytes in 0.015s)
--- correcting permissions
--- executing zergRush
[**] Zerg rush - Android 2.2/2.3 local root
[**] (C) 2011 Revolutionary. All rights reserved.
[**] Parts of code from Gingerbreak, (C) 2010-2011 The Android Exploid Crew.
[+] Found a GingerBread ! 0x00000118
[*] Scooting ...
[*] Sending 149 zerglings ...
[+] Zerglings found a way to enter ! 0x10
[+] Overseer found a path ! 0x000171e0
[+] Zerglings caused crash (good news): 0x401219c4 0x0054
[*] Researching Metabolic Boost ...
[+] Speedlings on the go ! 0xafd19fd3 0xafd3a837
[*] Popping 24 more zerglings
[*] Sending 173 zerglings ...
[+] Rush did it ! It's a GG, man !
[+] Killing ADB and restarting as root... enjoy!
--- WAITING FOR DEVICE TO RECONNECT
if it gets stuck over here for a long time then try:
disconnect usb cable and reconnect it
toggle "USB DEBUGGING" (first disable it then enable it)
--- DEVICE FOUND
--- pushing busybox
3199 KB/s (1075144 bytes in 0.328s)
--- remounting /system
--- checking free space on /system
0 KB/s (439 bytes in 1.000s)
df: /data/DxDrm/fuse: Permission denied
--- Free space on /system : 59% bytes
test: 59%: bad number
--- NOT enough free space on /system!!!
--- making free space by removing Google Maps
--- copying busybox to /system/xbin/
2099+1 records in
2099+1 records out
1075144 bytes transferred in 0.259 secs (4151135 bytes/sec)
--- correcting ownership
--- installing busybox
--- pushing SU binary
1389 KB/s (22228 bytes in 0.015s)
--- correcting symlinks
--- pushing Superuser app
3274 KB/s (785801 bytes in 0.234s)
--- cleaning
--- rebooting
ALL DONE!!!
created by DooMLoRD
[*] Before u begin:
--- STARTING ----
--- cleaning
[*] Scooting ...
--- DEVICE FOUND
--- pushing busybox
2099+1 records in
2099+1 records out
--- cleaning
--- rebooting
ALL DONE!!!
