Root Zip file for BakedSnack on Fresh?
tstartup
I'm using the current Fresh Rom. Over on the BakedSnack download page is a zip file with FM/news/hotspot etc....If I flash that zip on my Fresh Rom (to get those apps )...would that cause a problem. Thanks.
No, but do a nand backup just in case.
When I downloaded Fresh I noticed a file that said "fresh removed apk's" , I bet the things you want are in there.
True.
True.
Yes...I read previous threads and did find the FRESH deleted apks folders on the SD card...FM app will not install....found others in other threads that say the same thing..
But Thanks...!!! I will post what happens when I flash the BakedSnack zip on top of me FRESH Rom....
Well that's because you have to use adb to push certain removed apps back on the phone. Let me know if you have issues after flashing the baked snack zip and I will give you the directions.
