Help ZT-180 Microphone
trimpcs
Is there any app that can test the microphone on the ZT-180. I cant get anything out of it at all. Has anybody got it working? Will it work with a Skype app?:confused:
Hi, Did you find an app to test the microphone out? I ould like to test mine as well, thanks!
There has been some discussion on this at slatedroid.
One poster said he got his 0827 machine to run the app
com.tokasiki.android.voicerecorder.apk.
I tried instaling this on my 0827 machine and got it to work (sort of ) only once. I was able to record a short 5 second sequence and play it back. Then Android reported problems with it and the app had to be forced closed. I got nothing else after that.
At least it shows that the problem is software or driver related so it gives me hope that it will be fixed. A lot of people seem to be waiting for it. I have been using the machine for a month now and I'm quite happy with it.
I see where the microphone was working in earlier versions but I am happy with 0827 so I won't go back to earlier flashes.
Also I hope that UMTS 3g modems will get support in the next releases.
Since I got the tablet talking to my LAN things with the tablet have been looking up.
BTW If you copy movies to the SD card they play really well rather than playing them from the USB stick directly where thay are choppy.
