yes, open already. found these code on the other forum: for testing, works on our phone also some codes.
Dial Mnemonic Operation
*983*0# Menu (20:Battery/OLED/Back Light/Vibrator/Ringer/LED/Key/OLED off/SD/BT address/Radio Info/Memory/TouchPaint Test/Audio Loop/FM/Camera/GPS Test/IMEI/IMSI)
*983*3640*01# IMSI
*983*25# Battery Info
*983*31# OLED Test
*983*26# Backlight Test
*983*850# Radio Test 0
*983*86# Vibrator & LED Test
*983*84# Ringer Test
*983*07*01# Headset Test
*983*07*02# Key Test
*983*3470# LCD Test
*983*81# SD Test
*983*890# -
*983*26*# Radio Test 1
*#06# IMEI
*983*27274# CRASH Reboot
*#08# Test Flag [Note: requires QcNvTest.apk in /system/app]
*#09***# BT Test
*983*1275# _ASK Dev Info
*983*7# Menu (4:Version/IMEI/IMSI/BT address)
*983*3640# DOH+ Phone Info (inc ping test, radio on/off)
*983*636# MEM Memory Test
*983*28# BT Emode BT Test
*983*477# GPS GPS Test
*983*21# Audio Loop Test
*983*70# Automatic Inspection
*#18# LED Test
*#19# TouchPaint Test
*983*36# FM FM Test
*983*57# Factory Reset
*983*473# Camera
*#23# Video Camera
*983*10# Delete (Touchscreeen) Calibration File
*#25# FM Test
*983*2726# SIM Contacts Op 1
*983*37# SIM Contacts Op 2
*983*6726# SIM Contacts Op 3
*983*154# "test" Menu (12:Self-starting/Software Version/Hardware Version/PSN/Test Flag/[Completed]/Board Serial/Bluetooth Address/SMS security/SMS Registration Status/Flash Type/PRL Version/Serial Configuration)
*983*07# Menu (9:OLED/Ringer/Vibrator/Key Test/Audio Loop/Headset Test/FM/Camera/SD)
*983*5182# Dev Info
*983*7469# SHOW Automatic Inspection
*#26***# Sensor Test
*983*7936# QXDM Save Qxdm in log system
*987*0# Menu (4
roduce Information[->"test" Menu]/Automatic Inspection/Factory data reset/Battery information)
*#27***# Compass Test
*983*87274# USBSI USB Switch Test
*983*06# BT Test
*983*564738# LOGSET LOG Set (inc sys_rw)
*983*93# FCC Test [Note: requires fcctest.apk in /system/app]
*983*2377# CFQP Call Forwarding Query with PowerOn
*983*24474636# CHIPINFO Chiper Test (chip info) [Note: requires ChiperTest.apk in /system/app]
*983*29873283# AXUPDATE Touchscreen Updater
*983*73564# SDLOG SD Log
