ZTE stuck in boot animation
snake0463
I've been looking and found nothing for my phone. I put a boot animation on my phone which lagged and I was going to change it back and now it gets stuck at a frame and doesn't do anything, it's been sitting like this for the past half-hour and I don't know what to do, I have CWM recovery and I don't know what to do. Help?
Power,phone off by removing the battery. Then put the battery back in, hold down volume up, home and power at the SAME TIME until ClockworkMod comes up
I hope you made a backup so you could go into backup restore and restore it
When I mod roms I always make a backup before in case I get a boot loop like you just did.
I suggest going to the ZTE forums here and ask the all things root sub forum this question. Some have backups of the stock rom. Rooted and all. You can find some way of putting that onto your sd card and flashing that under restore. You can format the device but unless you keep booting into recovery it won't work
