tonyfughter14
I Need Help Fixing Me Zmax Plz Help Me!!
My Phone Was Rooted But I Soft Formatted Then It Turned Off Then It Kept Restarting I could access ftm
yesDo you know how to use adb? (Or better, do you have it installed?
There is no "backup and restore" option in twrp. There is a "backup" option and there is also a "restore" option.Like I Went To Backup And Restore And I Formatted it
do you have the links if so leave them in the comments i have school but i will come back in 7hrsUse ftm mode by pushing power + volume down, then you need to flash a twrp recovery using your adb, with phone connected to you computer you can download a twrp image from Masterchief87 he has two zips with it inside them, copy the twrp recovery to sdcard with
adb push twrp recovery.img
Then use dd comand to overwrite your current recovery
dd if=/sdcard/recovery.img of=/dev/block/platform/msm_sdcc.1/by-name/recovery
Rename recovery to what ever your twrp is named, this should get to into twrp, once inside clear cache with twrp, if you still have a syste! You should be able to boot now, if not then flash the stock ROM that Mon has called butternoob, you should be able to boot up then
. All the links you need are in my post http://androidforums.com/threads/rooting-links.918933/do you have the links if so leave them in the comments i have school but i will come back in 7hrs
Droidislinux made it simpler and just added all links to one post to prevent people form searching for stuff mc87 is aware that I collevt everything in one post ( of course I give credit )Masterchief87 made the zips, ask him, butternoob stock ROM is on here in its own thread, S
So is masterchief87's zips just look threw the root zte ZMAX thread
I know your not talking to me directly and i j ow its not your job to help us but i greatly appreciate it. But i did read everythimg 30 times. Ive used adb multiple times in the past just not to this extent. I got to the part in the root guude that says uninstall kinguser. I coundnkt uninstall kinguser so i figured id do a factory reset and start fesh. Now im bootlooped. And possibly what you said. I can enter adb through ftm mode.It sounds like you used the permanent root script that gets rid of the stock recovery to root your Zmax, then tried to do a factory reset after you had already removed the recovery. You have to pay more attention. Read EVERYTHING before you flash something. If you have to read it 30 times before you understand then either read it 30 times or don't use it.
Thank youWhen I get back home in a few minutes I'm going to see what I can do.
