JerryScript
Android Expert
I had modified my build.prop with the GPS fixes, so I couldn't flash the ZV6update. I took the build.prop from the stock ZV5 kwknott posted, and it made it through the verification fine. Thanks knknott!
http://androidforums.com/threads/lg-volt-stock-zv5-rooted-rom-odex-deodex.896545/
BTW- I used TWRP 2.8.7, and it flashed the update twice, with a reboot in between, then rebooted and went through the updating apps process. Once it finished, I checked the software info screen, and it shows ZV6 for both build and software. I did have to use dptools to re-root.
Thanks again @kwknott, with your permission, I'll attach the build.prop to this post to make it easier for people.
