Root ZV9 Update Problem
Petrah
Psychotic Female
Im on step 5 from here:
It didn't reboot, so I pulled the battery as instructed and then did hold home button, volume down button and power button till I saw the LG logo, let the buttons go and it booted into recovery. However, I see the default Android recovery. Is this normal??
I flashed Bobzhomes recovery with the FlashImageGUI (already had it and have used it several times), so I know that recovery was there.
This is what I get now on my PC command prompt also, which is a tad different than before:
F:\SDK\platform-tools>adb devices
List of devices attached
A0000028EE9E73 recovery
Am I OK, or did something get borked? I'm still sitting at the default Android recovery screen on my phone until I know how to proceed.
When you installed the update it will return your phone to 100% stock. You need to boot into stock recovery as step 5 is instructing and reflash update again to install radio as only stock recovery can do it.
you are fine, just continue the steps
You will need to use stage 2 to reroot and reinstall custom recovery
kwknott,
Thank you so much! I kind of figured, but I wasn't 100% sure. Wanted to verify that I was seeing what I should be seeing before I went further.
Thanks again!
