deathbeast
ok so i recenly fixed my esteem and now i wanna update but the lg update tool says im up to date yet in settings im still on zvd:/ any help?????
ok so i recenly fixed my esteem and now i wanna update but the lg update tool says im up to date yet in settings im still on zvd:/ any help?????![]()
same here
Are you guys rooted and make sure you have all the drivers installed if all drivers installed power off computer/laptop and wait for a minute or two and power back on and then you should be able to upgrade if not u can try the zve tot . post back if it Dont work and I will post the zve tot URL
Do u know how to use the lgpnst
I have it running and all but i cant get it to reconize my device it just says unknown device nd iv tried to get the vs910.dll to work but it doesntOK this is the zve tot I was referring to
Here it is folks! MS910ZVE_01.TOT - Android Forums
Use that with the lgpnst
Did u turn off the user control in your security
