Android auto
Waze...
Hey, I get it and it's frustrating, but I stay away from Android auto because of its constant problems. Really not worth the headache. Alternatives?
Waze works like a charm but not sure if it's going to do what you are looking for.
Lost whatsapp chat
I have thought about how to help to return all information. Remember how I had the same problem with the hipaa compliant video conferencing(seecure.com) after changing a phone. And surprisingly was a good idea to apply for the support service or customer service. So it's, and my advice to you, at least one reason to call them, and in about 10 min you have all data restored. And if an issue is in something else, it'll be easier to know it. Reply to me if you have progressed with your problem, and I'll try to help if not.
Best wireless charger for S21?
I use the standup wireless charger I purchased at Verizon for my Note 10+. It works flawlessly with my S21 Ultra. However, a quick search on Verizon's site did not yield the exact model I have.
I would suggest buying from someone Verizon like that have dealt with customers with your phone and wireless charging needs. If they sell you a charger that doesn't work, a return / exchange should be simple.
Help Nexus 7 won't charge wirelessly any more
OK here was the culprit.
I had notice what I thought was a slight position sensitivity when placing the tablet on the charging coil, but it turns out it was slight *pressure* sensitivity.
The battery is original, and performs fine, but the tablet had been left on the patio (in Arizona) and so it overheated. There was not a slight bulge to the back cover. Opening the unit revealed the LIon battery envelope was "ballooned".
The "ballooned" battery pressure was pushing the back cover away sufficiently that the small "S" shaped contacts to the charging coil on the back cover were intermittently making contact to the main circuit board.
A temporary fix was to slightly "stretch" the "S" contacts. This worked reliably for the week it took to get a replacement battery. Prior to the battery replacement there was a noticeable bow to the back cover, but also a slight bow (about 1mm) to the actual display...which was scary. With the new battery everything is back to normal.
Thanks, all, for your helpful relies.
Thank you for this post! Fixed my mystery issue... The NEXUS 2013 will never die!
Still so hard to find a tablet with Wireless Charging. LineageOS has mine running Android 11.
Help How to remove Alt+s=ß mapping?
I found a workaround that I think will work for me, which is to remap left Alt and right Alt to Esc using external keyboard helper. The program I am using (emacs) treats Esc almost the same as Alt. Not quite the same, because Esc is a prefix rather than a modifier so to get the same result as Alt-n-n-n you would need to put Esc-n Esc-n Esc-n, but that's only slightly inconvenient.
Need Help with Galaxy S10e
As a follow-up... Nothing I tried worked. I asked a tech who came to the house to replace a hard drive on one of my laptops. How ironic - he had recently had similar issues with he and his wife's phones. My issue was between two android phones. His is android and his wife's is iPhone. To this minute the issue isn't resolved. That said, the fact that it happened to someone else who is fulltime IT service guy for android and pcs gives me hope that when I trade in my phone in February the problem will disappear! :)
How much we can Implement ads on an app
This is for the same app you were praising for being ad-free in one of your other threads? Just curious, since you have posted to the forum that was created for that app in response to your post.
I'm not an android developer, but there are rules about what types of ads are allowed, which should be documented by Google if you are uploading to the Play Store. The trickier thing to judge is what your users will tolerate (as discussed above). BTW I would immediately delete any app that ever showed me a 30 second ad (no second chances, it would be deleted there and then, no matter what the app was).
Since this particular app is a VPN, users will probably not be interacting with its interface very often, more likely they just set it up and leave it running. In which case they will only see your ads on the occasions when they interact with it, which I would think would limit ad revenue. I'm pretty certain that the Play Store forbids any app from displaying ads other than when the app is open on the user's screen (something they eventually banned after months of outcry about apps that did just that). Apps that did that were regarded as malware by almost all users, and there was a time when a common question here was how to identify the app that was doing this so that the user could delete it.
Help Why does my Pixel 6 Pro when idling uses more battery than my Nexus 5 when idling
Though to be fair if auto brightness is using power while the display is off someone needs to send Google developers a "software design for dummies" book...
(And if the display isn't off when the phone is idling then there is your problem ;))
It will use the lux sensor to sense the surrounding light, whenever the screen is on.
If auto brightness is not used, then this sensor is (should be) not running.
Also, when the screen is on, the actual act of Auto Brightness adjusting the brightness up and down uses power.
Not to mention that now, on modern devices, this auto control also supposedly 'learns' your brightness habits.
Mine did not (after a week or so), and I was constantly battling the stupid auto crap in order to properly/comfortably see the screen.
It was crazy!
I would go outdoors into bright daylight, and the auto crap put the screen at ~80%.
I would pull down the quick settings, turn the brightness all the way up, just to see it go right back down.
Again and again.
Likewise in the opposite, it would hover around 70% to 90% indoors with a 40w equivalent bulb across the room.
Down to 25% I would place it, only to watch as it creeped right back up.
Stupid automatic junk.
It wasn't learning anything from me, unless I was telling it how to piss me off while I was talking in my sleep.
So I put an obsolete app called Brightness Control (from Curve Fish Apps) on it, and it gives me quick, pinpoint brightness control even faster than Auto Brightness could figure out where I did not want the brightness to be.
ROMs 【Help】 a issues about android OOM
I meet a OOM, in android 9,10,11, logs as follows:
Failed to allocate a 1228810 byte allocation with 24149440 free bytes and 256MB until OOM, max allowed footprint 292719044, growth limit 536870912; failed due to fragmentation (largest possible contiguous allocation 219232 bytes)
it happens when call "ByteBuffer.allocateDirect"
i am wonder why art do not arrange the art memory since still have enough memory.
Could some one enlighten me?
Phone goes to sleep and freezes terminal execution
Shoot, I really thought that would do the trick. I'm afraid I don't know what else to try though.
Maybe it is working now with the following steps: I opened the terminal and set wakelock on, then I opened a new window inside Terminal and killed the old one, then I worked on the second. I should have launched during the night a counter to be sure but since I am in a hurry I launched my program and I have the feeling it works because I had some results in the morning, even though not mathematically sure, afterwords I will check the counter
Filter
