New App: Jumping Will (Version 2.1.2)
- By App Update
- Apps & Games
- 0 Replies
EXTRA INFO
- Rating: 4.6
- Installs: 10+
- Download Size: 31M
- Version: 2.1.2
its called planned obsolescence. things will break down or support will cease to exist. batteries are designed to last about 3-4 years. you are probably lucky enough that your phone has a removable battery. most phones now days do not have this. also developers stop supporting older os systems as they continue to develop for the newer ones. so apps will either slow down or stop working completely.Yes it uses Android 4.4.4. Unfortunately I cannot get an Android OS from Samsung newer than this for my phone. I could put another OS on it, but why should I? I am also of the generation that believes that if something cost me £300 in 2015 and is only 6 years old then it should not be classed as obsolete so soon.
I again complained to WhatsApp about this stopping on 22nd July. They now replied with "We are aware of this issue and it will be fixed on next update". So I was correct, they changed something that broke it on older phones. This thread can now be closed. Thank you for your replies.
Why did you decide that your husband is cheating on you?
Okay. Congratulations.Thanks James, I had the same trouble, now it works
on a PS4? never heard of such a thing. what game is this for?I'm curious if anyone knows of a stat tracker that dates back to the game's start or shows you how many kills an account has ever gotten in a single match.
I have a friend who (supposedly) scored a 21 kill game a few years ago, perhaps four years ago. We also don't have any proof. The majority of the programmes we download app don't allow us to go back far enough.
Any assistance would be much appreciated! (PS4)
Then why post a response? And you forgot the colon in your sad face emoticon.
@puppykickr Yes the Client is using an android, I am using apple.
@savim bro I wnat solution for android 6.0 by mounting sd card on it
its not only how you root the phone that will determine how yo unroot, but what phone you have as well. specific phones will have a certain way to unroot.....so it depends@ocnbrze bro thanks a lot for replying by which method or rooting SU magisk kingoroot twrp rooting the data is not wiped after unrooting. Secondly does symlinks of link2sd works after unrooting...as link2sd runs scripts and if data is not wiped on unrooting then does the scripts of link2sd runs without root privilage or not
thanks a lot
You will have to contact PUBG about this. You might need a different form of payment.Why I can't by bc in pubg lite when I'm purchasing it so there the system shows that the payment is unavailable
