The Maze of the Underworld[FREE][GAME]
The Maze games are very helpful to sharpen your mind. Play the "The Maze of the Underworld" puzzle game and have fun!
This game will train your intelligence, visual memory, and mental speed and help you solve perplexities more easily. Let your brain learn and develop skills with this game.
Download and start solving puzzles now with The Maze of the Underworld !!
Download to Google play:The Maze of the Underworld
wD2X7z06rK9oCRgrM10gmF_vgNYVmc7LsHb_xizFjsxYpnJH2RahGyiSuF-6V3NkEsE=w2504-h1200
K55J5F6T-v3pO6kqQ9f5rM-PndLgXLvrdSIKore46qb8Cyew7CLY_EEBx1ayyoE_nQ=w2504-h1200
upgrade OS on my RCA Viking Pro tablet?
The reason it slowed down the tablet, was because the stock RCA ROM was designed and built primarily for that particular model and make of tablet, but a custom ROM may work on the tablet, but it wasn't designed and built specifically for that make and model of tablet and therefore, when the boot sequence starts the OS, tried and fails to enable certain features that maybe present in other devices but are not present in the tablet, and thus waits for a timeout, causing slow sluggish operation, whereas, the stock ROM, only enables modules that are present on the device, also, when someone flashes a custom ROM, there is no stock ROM available anywhere to revert back to, the manufacturers do not support users that flash their devices, and therefore do not have their stock ROMs available to re-flash, plus unlike a PC, there is no way of literally backing up a devices entire stock ROM, so that it can be restored later if anything goes wrong, and in that case, the only solution is the sledge hammer.
That's why I advise people that want to replace their stock ROM with a custom ROM which is already rooted, instead of actually rooting their device, NOT to flash a custom ROM, because as I said, there is no way of backing up the entire stock ROM, also if something does go wrong with the custom ROM and the device is literally 'bricked' and the custom loader doesn't work either, then it's back to the sledge hammer. And that's why I'm never going to flash any of my devices I have now and may get in the future with a custom ROM, unless that ROM was designed and built specifically for a particular device, such as , if there was a way to download a device's stock ROM, then a way to create such a custom ROM would be for that stock ROM to be 'ripped' from the device, modified, then re-flashed, that way the custom ROM would only be for that device.
The problem with custom ROM's is that the ROM developers try to make them as generic as possible, but there is no such thing as 'generic' when it comes to Android devices, as differing manufacturers build their devices differently and as such their stock ROM's are also different too.
Command and conquer tiberium alliance on android?
yes mabye Command & Conquer: Tiberium Alliances is the new-born product of 16-year-long Command and Conquer classic game series developed by AE,
Well the website just giving me a "This domain is registered for one of our customers.". Which of course we can't really help with. Maybe it's been discontinued and pulled?
And the only "Command & Conquer" can find for Android now is this, from EA.
https://play.google.com/store/apps/details?id=com.ea.gp.candcwarzones&hl=en
Accessories A tip on how NOT to get ads during playing some games.
OK, here's a solution to stop those annoying ads from overtaking your gaming pleasure, especially when you're about to touch an area, then just as you touch it a full screen ad appears and you accidentally start the play store to download it, this is NOT acceptable, this tip only works with offline games, online games need the internet to play, but offline games only need the internet to flood you with ads, so, you can either disable mobile data and WiFi, or go to Google play store, download and install 'NO root firewall', start it and allow the permissions, then when you touch the 'start' button, it'll ask you if it's allowed to create a local VPN connection, don't worry, it's not a VPN as we all know such as most of the online VPN's, etc etc, but it's similar to how a loopback works, when the game requests internet access the firewall will stop it, and thus prevent the ads from appearing,,,,now, don't forget, some games have the ads built in, and other have to connect to the internet to fetch and display them, but if they can't get the ads, then they can't be displayed.
I use No root firewall for most of my games I play on my tablet and I don't get one ad, now, unless you disable notifications for the firewall, you'l get annoying bleeps etc etc from the firewall saying '????? wants internet access', so it would be better to disable all notifications from the firewall, but REMEMBER to open the firewall app, then touch the 'STOP' button to allow the rest of the device internet access.
QUESTION ABOUT INSTAGRAM
Surfing the internet I read an article on a website. In the article there was an Instagram video with several icons (likes, comments...) and also a strange icon ( I attach a photo taken from the web as example,but the situation is the same)
From the left:there is the like icon (heart),comments and then....? What does that symbol means (the arrow pointing up)?
I tried to click on it but nothing happens, if I click on the other icons it redirects me to instagram (ex: if I click on the like icon I get the message "log in to instagram to like", the input occurs). I repeat that I was on another site, I read an article with this video and this icon. What does it means? Did I accidentally share something ?
That is the share icon, it look different on Android though. The photo looks like Instagram on iOS.
Internal memory nearly full
The first thing to do is to identify what is actually using the space. Without knowing that any changes you make may be missing the problem completely.
Can you post some screenshots of what the system storage menu says? It's important to know that a user-installed file manager won't be able to show you anything about the private data of apps; my advice would be to see whether the "app manager", as I believe Samsung call the "apps" section of the system settings, can show you your apps ordered by size (some can, some can't. If you can't see the option look for a 3-dot menu icon and see whether it's there). If you can identify which are the big space users you'll know where to start: simply clearing caches of browsers or social media apps can sometimes free up GB of space, and if you are going to uninstall apps (a more permanent solution) then knowing which ones are worth uninstalling is important.
Those of us who don't have this device might also like to know how much storage it has in the first place. If it's an 8GB device you'll probably always struggle with storage (at least half of that will be used by the OS, so you'll only have a few GB in total even after a reset).
As an aside, ES have had a lot of privacy and data protection issues. They wouldn't be my first, or even thirty-first, choice of file manager.
Filter
